A chain can stretch and also tear.
But Honda engines are not known for it....
Hi,A chain can stretch and also tear.
That was not the result of a lack of valve adjustment. That was due to a failure of the cam timing chain system. Either the chain broke or it got badly worn due to a lack of proper lubrication and jumped time. Timing chains don't stretch, they wear and get longer due to the accumulated play in the links and link pins.Hi,
Saw this!
This can also happen if your Timing Belt breaks, but...
The K24 Engine has a Chain so doubt it broke!
Adjust your Valves, Folks!
Hi,That was not the result of a lack of valve adjustment. That was due to a failure of the cam timing chain system. Either the chain broke or it got badly worn due to a lack of proper lubrication and jumped time. Timing chains don't stretch, they wear and get longer due to the accumulated play in the links and link pins.
As per your definition, this is actually timing chain “stretch”. 😉That was not the result of a lack of valve adjustment. That was due to a failure of the cam timing chain system. Either the chain broke or it got badly worn due to a lack of proper lubrication and jumped time. Timing chains don't stretch, they wear and get longer due to the accumulated play in the links and link pins.
Great Sound Advice, Thank YouHi,
Saw this!
