1 - 8 of 8 Posts
2003 Honda Element 5 Door EX (2WD) KA 4AT
I have planned making a trip of ~800 miles and I'm considering on replacing two of the tires.
Mostly because one of them is damaged on the side. It is currently on the rear on the copilot side.
209136
and looks like one of the other ones slowly loses some aire over time.
They are ContiCross LX 215/70 R16 100S. I got the 4 at the same time and all four have the same wear.
209137
About the suspension, there is a sound in the back every time after passing a bump.
I read it could be the stabilizer or the links, but they look fine and don't make a sound when I try to move them. The only thing is that the bushing is a bit loose and I'm considering on replacing them.
I fear I could need replace the shocks as well.
Go with the oem Honda sway bar links and bushings. Great parts. I just bought Yokohama avid touring s tires highly rated for long drives. Check out your lower ball joints and outside tie rod ends.. Get delphi... Monroe makes a complete strut assemblies with spring and top mount for basically a little more than a kyb strut alone
Thanks Sandmonster. I went with continental and installed the new ones in the from.
While installing the new tires, the mechanic pointed another problem. The bushings on the control arms :(
The one on the driver's side
209145
Passenger side
209146
The tire shop is quoting $140 to replace the bushings.
If it is $140 for both, that is a good price. These a kind of a PITA to do. See if you can find genuine Honda bushings, I think they stopped making them though.
I doubt they will use genuine parts, I think they use moog parts, I will confirm once they finish the job, I just took the E to the shop.
See if Sankei 555 makes the ones you need they are an excellent Japanese OE supplier, I have used their parts on a few cars, excellent quality, they last and are usually cheaper than Honda
Just added 2 tires ..Where do you install two best tires? Costco disagrees with me. I think the 2 best tries should go on the front since the Element is front wheel drive. Costco has the opposite opinion, they think best treaded tires should always go on the rear....
1 - 8 of 8 Posts
