Thanks for the info, do you figure most of the shock spring setups for the element are compatible with the SC? Is ride height the only thing affected?
So to your knowledge, if you have an SC you can basically order any strut spring combo that would fit any other element and bolt them in?I know of people doing the opposite. Putting SC struts on other elements for a lower ride hight, and the two main things I’ve learned from those posts are that:
1. The only difference between sc struts and other model struts are the ride height and spring rate, meaning that if you use stock struts on an SC you will get a smoother riding vehicle at the height of a non-SC element. Should smooth out the ride a bit and because the SC has the 18 inch wheels cornering performance should remain roughly the same.
2. If you want a new SC strut assembly you will need to go through Honda. A set of four complete struts and springs is ~$900. Buy online unless you get good discounts from your dealer ?.
Hope this helps.
Bingo bucko. It will raise the car a bit, but not anything monster truck status. Should be a more pleasant ride as the SC’s spring ratio is WAY beefier than it needs to be.So to your knowledge, if you have an SC you can basically order any strut spring combo that would fit any other element and bolt them in?
Okay, so I do apologize for the SUPER late reply to your question....but it does look like you received some solid information from fellow EOC members!BallBearing, Thank you for the info, I"m in the same predicament now where I need to replace the struts on my 2008 SC.
I did my due diligence and called Monroe as they list a part number that most sites claim will fit (G57223 and G57222 ready mounts). I spoke to their support division and after a lengthy phone call the representative confirmed that they will not fit the SC model and advised they will update their fitment guide for those part numbers
I also contacted KYB as they are the OEM provider for Honda, They too also told me they DO NOT carry a part number for the SC and advised I contact the dealership.
So here I am, contemplating your install, I don't know that I'll be too happy with the taller stance, so here's a question for you. Don't know if you may know, but if the aftermarket setup has taller springs, do you think that replacing those springs with the factory SC springs will give me the factory height?
The only other thing I can think of that won't allow for that, is the travel on the shock its self
Any feedback would be greatly appreciated..
Thanks again for the post
Great info, H and R is top shelf for suspension springs, good to know there is a practical solution for SC suspension replacement thank youSome yahoo installed those EX/LX ready struts on my SC right before I bought it, so it bounced around like a Jeep and rocked and dove and squatted uncontrollably. Since they were 03-06 springs/struts, I just installed a set of 03-06 H&R springs on them. Problem solved - I’ve retained the SC ride height and probably improved the handling, and only had to drop $200 on it.
One can use standard struts for a 2007 and beyond with SC springs. I recently did this and one does end up with nearly normal SC ride height. It doesn’t take much to disassemble the struts. Oddly the SC spring is short enough that one does not need to use a spring compressor to reassemble the standard strut with the SC spring.
The mounting of the tie rod is higher on the strut on a regular LX/EX unit than on a SC strut fyi
When you did this did you have any knocking from not having the spring compressed? I just bought my SC, new struts from Honda are on back order and the noise from my front end is driving me nuts. (I already replaced ball joints, sway bar links, bushings, and the lower control arms. Its definitely the strut now.)One can use standard struts for a 2007 and beyond with SC springs. I recently did this and one does end up with nearly normal SC ride height. It doesn’t take much to disassemble the struts. Oddly the SC spring is short enough that one does not need to use a spring compressor to reassemble the standard strut with the SC spring.
Not sure how anyone was able to make non-SC shocks work with an SC spring swap. The strut rods are an inch too long and the spring is not tight enough and hence will knock over bumps. That's why you can mount the springs without a spring compressor; not good. Found this out the hard way and applies to both the front and back. This on a 2010 SC but I was able to get the correct OEM shocks from hondapartsconnection.com without issue a few months ago. Picture is of the rear shock. Non SC on left.When you did this did you have any knocking from not having the spring compressed? I just bought my SC, new struts from Honda are on back order and the noise from my front end is driving me nuts. (I already replaced ball joints, sway bar links, bushings, and the lower control arms. Its definitely the strut now.)
Thank you for the information and saving me the headache, I was about to buy 2006 EX struts and lowering springs. I was reading that the tie rod mount is higher and was concerned with premature wear and tear on the rack and pinion, as well as issues in alignment. I am impatient when it comes to noises in my cars. I went ahead and ordered the new front struts from hondapartshq.com I will wait it out to get the right ones.Not sure how anyone was able to make non-SC shocks work with an SC spring swap. The strut rods are an inch too long and the spring is not tight enough and hence will knock over bumps. That's why you can mount the springs without a spring compressor; not good. Found this out the hard way and applies to both the front and back. This on a 2010 SC but I was able to get the correct OEM shocks from hondapartsconnection.com without issue a few months ago. Picture is of the rear shock. Non SC on left.
I also ordered the top mounts since I was taking it apart anyways. I was reading that these go bad too and should be replaced on the front struts. Part# on a 2010 SC are 51925-S6M-014 and 51920-S6M-014.Thank you for the information and saving me the headache, I was about to buy 2006 EX struts and lowering springs. I was reading that the tie rod mount is higher and was concerned with premature wear and tear on the rack and pinion, as well as issues in alignment. I am impatient when it comes to noises in my cars. I went ahead and ordered the new front struts from hondapartshq.com I will wait it out to get the right ones.
You have had no alignment issues? I know there the tie rod attaches slightly higher on the older struts.No knocking or noises from mine. My suspension is basically an 03-06 with lowering springs, and it’s fine.
