i just finish installing my system. i took the drivers seat out to run the wires under the floor mat. so i disconnected the seatbelt wire and the air bag wire. now the freekin air bag light stays on. when i turn the engine on. i tried to unplug the battery and reset it but no luck. does anyone have a clue on how to reset the air bag sensor?
Yup - lizzurd is right. The warning light turn off sequence is a timed procedure and typically requires the dealer to do it. What probably got you was that you disconnected the seat belt wire and then turned on the ignition. This is a big NO NO with honda products because it cause your air bag light to remain on until it is reset. I am speaking with an air of experience here - did the same thing to my 97 Civic and cost $35 to have the light reset.
