hi...i went to bestbuy last night to get an alarm...it is $220 install included...the installer told me that it is around $100 in parts...PLUS : (here is the weird part), I would loose a key...he needed one of my keys to by-pass the honda kill system...they key would be mounted under stearing wheel .... sounds really really weird ... maybe emass can explain...take care...robert
Does your alarm include a remote starter? The chip in the key has to be installed into a remote starter to by pass the immobilizer.
You do not need to loose one of your keys.
You can buy a $30 Key transponder bypass for the honda. This will learn the code for your key and will send the signal to the Ignition/ECU to allow the remote start.
If that doesn't work, go to your dealer and buy a key. Do not get it re-keyed. U will need this key for your remote start. But first, you will need to re program it and learn the codes of your element.
You will also need a universal key transponder bypass module. Your new key will be inside this module, tucked and hidden under the dash somewhere.
The reason I said to not get your new key re-keyed is just in-case someone finds it, they cannot use it to start your vehicle.
John
