Hi Everybody,
I've got a dealer-installed alarm that I'm having trouble figuring out.
What happens when I click the "Lock" button 1, 2 or 3 times?
Similarly, what happens when I click the "Unlock" button 1, 2 or 3 times?
If I don't press the "Lock" button, close the doors and leave the car for about 2 minutes the alarm goes off. I don't like that! Anything I I can do to change it?
If you press the lock button once, all the doors close. If you press it a second time, the you will hear a beep confirming all the doors are locked.
If you press the unlock button once, the driver door opens. If you press it a second time, all the door open.
Go into the alarm manuel to change the setting you are most comfortable.
Thanks for the clarification - now how about the other issue?
If I close the doors and leave them unlocked for ~2 minutes and the alarm goes off. Anything I can do about this?
Hummmm..... i leave my doors unlock all night long and the alarm doesn't go off. The only thing i can suggest is go to the manuel and look up your problem or call you dealer :D
I was lucky when my dealer installed my alarm, nothing abnormal happens like the alarm goes off or the door locks itself after 30 seconds.
I hope this helps.
