It's been a little under a week since the original installation of a black grill from C.R.....and this morning I noticed that the upper grill had come appart from the OEM grill......I noticed the 1st day that the clips for the upper grill seemed a bit small compared to the square holes they're suppose to clamp on to......has anyone else had this happen??....
I may go ahead and get some washers and put them in between the clip and the turning screw....any comments...? :roll:
Mine has done than twice now, where one upper clamp has come loose. Luckily, we noticed before the second one came off. Let me know if the washers make a difference.
The lower grill has been fine.
Kristi
I did this some time ago. I was very disappointed to see how close the fit was to the grill. I added a big black rubber washer to stop it from puling through and a steel washer over it to clamp against. Works like a charm. And yes, you have to take the radiator cover off. But that's dead simple. :D
[quote:dcaf9560b4="HEK"]It's been a little under a week since the original installation of a black grill from C.R.....and this morning I noticed that the upper grill had come appart from the OEM grill......I noticed the 1st day that the clips for the upper grill seemed a bit small compared to the square holes they're suppose to clamp on to......has anyone else had this happen??....
I may go ahead and get some washers and put them in between the clip and the turning screw....any comments...? :roll:[/quote:dcaf9560b4]
It's happened to me once. I'm about to take the top cover off and use some black cable ties.
