1 - 2 of 2 Posts
Greetings EOers.
Well, without going into the silly thing I did to cause my issue, I need some help with the antenna assembly. Well, ok...I backed up into my garage door and snagged the antenna assembly. As you can see from the picture, broke it clean off :-(
As you can see from the picture (I am standing behind my Element, pointing the camera toward the front), there is now a gap between the base of the assembly and the roof.
I did a search and couldn't find anything so my question is, is there a proper/good way to remove the base?
I can't push it back down flush, so I'm guessing I need to fix a clip or what ever the securing mechanism is. Of course, I'm going to need a new antenna.
Thanks in advance,
Justo
1 - 2 of 2 Posts
