Hey folks-
I was wondering if anyone tried installing the SC Suspension parts on a regular Element (EX)?
Particuliarly the OEM complete struts, including springs, dampers, and topcaps front and rear, also OEM sc rear upper control arm.
Will it be plug and play? Hows the ride over bumps and turns? The current set up I have is pretty bouncy and harsh over bumps.
Any advice would be great.
Thanks
before i swapped out my stock for eibach the truck rode great. handling was good and not too stiff. they will bolt right up to the factory mounts and such in any model.
Aren't the factory SC springs wound up differently? Anyways, I think it should bolt on
negative. all the 07-up have the front left spring wound in the opposite direction as the 06-prior, but this wont matter if the entire strut/spring assembly is being replaced. and the stock sc spring themselves would work with the 07-up struts if someone really wanted to.
