1 - 14 of 14 Posts
I'm approaching the tail-end of an audio install in my 2009 Element. As a heads-up, below are a few pics of the changes. With much of the interior panels removed, this job also included the re-routing of a video feed from my back-up camera to the new head unit, and the installation of a new circuit for 12V socket/USB charging in the back passenger area. Oh, and for the little one: a feed of wiring to a dedicated rear video monitor.
Enjoy and wish me luck on wrapping up the job! There are a few bugs to iron out (noise suppression :|) and a protective cover to place over the amps to retain some functional cargo usage.
Gear list
Head Unit: JVC KW-V30BT, with MHL cables for two-way control with Android and Apple devices
Four-Channel amp: JBL GTO 504EZ
Mono-Block amp: Pioneer GM-D7500M (kept from a previous vehicle)
Subwoofer: Fusion 12" Powerplant series, within a factory ported and tuned wedge enclosure. This sub and enclosure are far bigger than what I would have gone with, and result in quite a loss of cargo room, but I already owned the item from a previous vehicle and was very impressed with its performance. I'm hoping to shake the dust off of it from sitting idle for about five years!
Speakers: JBL GTO 628's in the front, JBL GTO 638's in the rear, and JBL GTO 18T's in the pillars. I've had these speakers for about a year now, but they were previously powered by the factory amp. What a difference now when they're each being fed 75W RMS.
If there is enough interest (reply below), I will take the time to edit and post a series of clips online for a walkthrough, explanation of why I did what I did, and for lessons learned, in case others may benefit...especially since I haven't seen too much in terms of mods done to '09+ models.
Cheers...:grin:
Looks good.
That's one hell-ov-ah piece of butcher block there. :-D
Hey there,
I retained use of the steering wheel controls by using a steering control adapter by PAC. With the purchase made from Crutchfield, the included American International kit was handy for its double-din brackets, fasteners and facia trim, as was the Metra wiring harness. Only a few wires were used in the harness meanwhile, as I wasn't re-using the stock amplifier or subwoofer in my set-up. Note that if you're considering a head unit replacement, it is worthwhile to check your OEM antenna harness end type; the one shipped by Crutchfield was not a match so a few days were chewed up while waiting for a replacement in the mail. And as a far as kits go, I also bought a Sirius SXV-200 to continue with my SiriusXM subscription, albeit with a new head unit.
Discussion Starter #6
Hi edubdeuce22, the manner in which the tweeter is mounted will depend on the type you end up buying. When I have a chance this weekend I'll try to post a pic or video of this segment on the tweeter installation. One of these things I've been meaning to do for some time.
Nice setup! I'd love to learn how you did it. My first big upgrade on my 2007 ex will be the sound system... One day... :) thanks in advance!
Discussion Starter #9
Thanks for the feedback folks.
After about seven months of living with this set-up, I can say this:
- investing in an audio upgrade was well worth the money and sweat. The prospect of listening to my tunes with this system is something I look forward to every time I step into the driver's seat. The element offers a lot in terms of its interior space, acoustically-speaking.
- I've experienced no issues with the equipment itself, be it the head unit, speakers, amplifiers, or steering wheel control interface. Oh, I will say this though: for the Sirius XM kit, I'll eventually upgrade to the other type of antenna (~$35). The UFO-shaped one does a much better job than the small rectangular one that is supplied with the kit. How do I know this? Everything else being equal, I've tried both in the past and the UFO-shape one does a better job at maintaining a signal amidst degraded lines of sight.
- The cost of the JVC KW-V30BT was merited. The visual interface to tweak the EQ is so easy to use. And the quality DVD playback makes long road trips with our little one a world of difference.
1 - 14 of 14 Posts
