For those of you with lights on your cargo baskets, how did you route your wiring? Did you drill a hole in the roof? Run the wires through the hatch? Pics would be great! Thanks
I cant speak to others, but I went in through the upper hatch grommet. My entry point is covered by the trim, so you cant really even tell.
One bit of advice. I used to run the wiring from roof lights/light bar through the moon roof and you have to be careful to keep a loop of wiring up in the gutter below the glass or water will migrate down the wire and soak everything.
i run my solar wires inside the roof garnish down under the a pillar garnish and into the engine bay. then it goes into the cabin via factory hole located near the hood release cable hole. never had water problems and looks super clean. i would not drill any holes into the metal roof.
