1 - 2 of 2 Posts
Greetings, I went out to open the passenger side doors on my 2003 Element and the rear door won't open - it is jammed in place and will not unlatch from either the inside or from the side. The door handles will only partially operate, and it feels like something will break if I try to force it farther. The door is truly stuck solid. Any suggestions?
Cheers,
Jonathan in Woodstock, Conn.
Pop off the top of the rear plastic cover from the inside of the hatch.
You can reach down to where the lock mechanism is and open the door.
My lock bar came off the mechanism and did the same thing to me!
1 - 2 of 2 Posts
