Anyone know the size for the banjo bolt and washers?
I replaced my right rear caliper a few months ago. My brake warning light came on yesterday because of the fluid level. Found the soft line has a persistent but slow leak at the banjo bolt that must only leak under pressure. I don't see any puddles or spots on my driveway.
I don't have the specs, but "bolt, oil," Honda p/n 46462-SE0-000, is only about $6 retail.
But why do you think the bolt is at fault? There could be a tiny bit of foreign matter between the bolt and the hose hardware (including the copper crush washers). Also, have you tried retorquing the bolt to spec?
07 2wd 5-speedauto
The copper washers are not re-usable. One time crush and thats it.
I cleaned and retorqued the bolt and so far, all is well.
