The battery light on my 2004 E comes on intermittently. While driving, it may go off if RPM are above 3,000. While idling, it may or may not come on. I finally caught the light on while idling at home and checked the battery voltage: about 12.5. When the light is off the voltage is above 14. Last time I checked the cold battery it was 12.6. This has been going on for weeks so the alternator must be topping off the battery whenever the light is off, but I feel like I'm asking for trouble driving to work everyday. Loose connection somewhere? Bad voltage regulator? I replaced the ECM a few years ago, and the alternator maybe 1 or 2 years ago.
What's the condition of your belt? Maybe it's slipping?
Belt appears fine. Is the battery light triggered when the voltage drops below a threshold? I'm wondering if the alternator is able to charge intermittently and tops off the battery, which makes the light go away for a while (minutes, maybe longer). I still can make the light go away most of the time by keeping the rpms above 3000, but lately I need to go to 4000 or 5000 to get the light off.
Had alternator replaced. It was only 2.5 years old so mechanic only charged me for the part. Says my starter is drawing a lot of current indicating failure soon. I swear my E is a lemon, but I bought it used with high mileage (over 200k now and body is good) so what you gonna do. I love the car. Replaced engine (timing chain failure), alternator (twice), battery, AC condenser, I think the water pump, what's left?
Any time the charging voltage is less than the power required to run the engine, lights, and everything else electrical, the battery light will turn on as a warning.
Sounds logical ... lets use more electricity when we don't have enough to begin with. :oops: Backwards, but it works to alert you.
