* brakes should be "serviced" every year or 20k miles. I recomend Springtime for areas where salt/de-icer is used in the winter. Do the fluid replacement every 2-3 years or when pads are replaced....I tie this in with the above mentioned brake service when it is due
* Auto trans: every 25-30k miles simple fluid drain and refill. Replace the filter the first time, and maybe every other time after that.
* Manual trans: every 40k miles is fine
* Rear diff every 30k miles or so. Some like to do it a bit sooner. It is best to do it
before it starts makeing noise.
* Coolant: every 3 years or 45K or so.
*Tire rotation: first time at 5k, then every 10k miles
*oil changes: I prefer 5k, but many use 10k miles with good results....i'd feel more comfortable recomending the 10k if I knew synthetic oil and a quality filter were used.
* valve check/adjustment: if you hear ticking....or around 60k miles. It might be a bit premature, but checking is fairly easy, and it is better than running into problems later on. 90k is ok if you're not as paranoid as me.
*engine & cabin airfilter: 25k miles , but if you drive in dusty areas, or areas with lots of air polution I'd do it sooner, or at least check more often.
*power steering fluid: drain as much of the old as possible and replace with new when the old stuff looks dirty.....around 50k for most people.
Or in other words.....about 1/2 of the interval that Honda says.
