Does anyone know the biggest tires I can put on stock without any rubbing? I also will be installing a 2 inch lift kit in a week and wondering what the biggest tires i could put on it then?
(I have a 2007 EX MT)
EOC Rank: Crankypants
If I remember right, the size of tire you can fit is limited by what will fit without rubbing on the suspension, specifically the front struts. I don't think lift kits give you any more tire clearance, so the largest tire is the same regardless of the lift (of course with different wheels, or spacers on the stock wheels, you might be able to get slightly larger tires).
