1 - 8 of 8 Posts
Just got through rhino lining the E.. putting a basket on top with 4 4” lights, 1 22” light on front of basket and a 52” light bar under basket then wanting big mud tires and rimes 15” rims are on it now
Wheel Tire Land vehicle Car Automotive parking light
Car Wheel Land vehicle Tire Plant
2004 EX AWD
I would check out this thread as there is no single answer to your question: Tire thread
On stock 16" wheels, 225/75r16 and 235/70r16 typically work. The issue is the bottom of the spring mount on the front strut, more so than the wheel wells. But different wheels and backspacing or spacers changes everything. You likely can go bigger with some spacers, but there are just too many variables to have a standard answer. But the thread above should give you lots of options.
Nice.. while you're at it, give those headlights some love!
Does it really work
It takes about 45 minutes per headlight but works. My wifes civic was about as bad as yours when I met her. I got them looking damn close to new with this kit. It is well worth the effort since it gives you MUCH more light.
How long does it last, does it have to be redone every year or two? Thanks
1 - 8 of 8 Posts
