1 - 20 of 29 Posts
Okay my husband and I are "novice" mtn and trail bike riders....one reason for purchasing a small SUV was to make it easier for us to haul our bikes and gear to the trails and parks.......we bought our E almost two weeks ago, but are now in a bit of a quandry.
We like that you can get the bike kit for inside of the E....very easy to put in and out....but if we are going camping we will have a bunch of gear....does anyone have this kit? Have you used this? How much room is left for gear? Pros, cons, comments???
Also....we like the roof top bike rack, but how practical is this for us....I am 5'5 and my husband is 5'6....is it easy to get the bikes on the rack and secured? Pros, cons, comments.
Diane :)
Personally, I don't recommend the internal bike mount because you can fit 2 full-size mountain bikes inside without them. My wife and I (she's 5'8 and I'm 5'11) take our mountain bikes with us quite often. We just fold up the seats, put both bikes in, and then bungee them to the sides. We usually have to turn our front wheels just a little, but both fit fine and sway very little if bungeed/strapped well. Also, this allows us to not have to take the front wheels off (and bungee them) since that's what you'd have to do with the internal mount. We can literally have get our bikes in or out in about one minute. While I'm sure the internal mounts might be more stable, we just didn't see the need to spend all that money for something that we didn't need and that would be more cumbersome.
Regarding space, two bikes in the back (whether bungeed or mounted) leaves little room for anything else. We can get a bag, our helmets, and a few other things, but there's really not a lot of room for camping gear if you're planning on taking a tent, sleeping bags, a cooler, etc. If you can afford it, the hitch and a rear-mount rack is the way to go. Not only are the roof-top racks difficult to load (unless you're 7' tall), people tend to scratch up their paint a bit more when loading on the roof and your bikes will get pelted with all sorts of stuff while driving. Plus, you always have to be mindful of low overhangs when your bikes are on top, unless you're hoping to make it on America's Funniest Home Videos. The rear racks are a lot easier to load, will protect your bikes better (assuming you have the splash guards), can hold up to 4 bikes instead of just two on the roof mount (which is nice if you want to ride with friends but just take one car), and some of them can even tilt down or swing away so that you can easily open your back doors. REI (www.rei.com) has some of the 4-bike Thule racks for around $150, but there are all sorts of brands out there.
So, if you're just going for a local ride then toss them in the back and go. Otherwise, use the money you'd spend on the internal mounts and go for the hitch and rear-mount rack. Hope that help!
HondaHappy
Green 4WD EX
But to install a hitch-mounted bike rack, you would have to have the hitch, right? As far as I can see, it's somewhere about $500 USD installed.
Iskie
someone here suggested a small step ladder for the roof rack. Not a bad idea makes it easier to get the bikes on and off and takes up all most no space in the back.
I would prefer a hitch mount, and may go that way but the costs is high. A honda rack and thule bike mounts will set me back about 600.00 cdn. The hitch and rack would be over 800.00cdn
I had a hitch put on yesterday at a local dealer of hitches (not Hondas), $240 installed with wiring, and already had the bike rack (old Performance unit). The hitch was $160 and $80 for installation with wiring. I don't understand the other prices quoted here. Maybe I got a light hitch (@,000 lb capacity, I think). My local Honda dealer actually told me it was cheaper to go that route.
With the rack loaded in the middle of three spots, I could still open the back lift gate, an impossibility with my old Explorer.
But like others, if I have the room, I love just rolling the bike (54 cm frame) in without removing a wheel and clipping the bungee.
I am still looking into a roof rack for more carrying capacity. So far, that is a murky inknown.
Love your bikes. Keep them inside. You wouldn't put your kids, or your dog up there would you? I keep mine in the back, but I am not sure what I am going to do with our tandem since we sold the minivan.
You can check my post below titled "Bike Rack Question" were I added some findings, but you can easily get roof mounted racks that do not require you to take off the front tire. They are completly lockable and don't interfere in any way with the hatch or tailgate.
I am 6'3" so the height is not really an issue, but it seems that others have solved that by using a stepstool. I also am somewhat of a novice, but my biking enthusiast friends like roof racks for security and ease of keeping the total functionality of the vehicle.
Hope this helps!
I just put a "Hidden Hitch" on mine with a Hollywood three bike rack. The hitch should cost about 1/2 the dealer price of $300 (150) and you can do it yourself if you have a socket and wrench set. Simple install. The rack retails for about $150 also. Go to http://www.hidden-hitches.com/ I just went there and there online price is $100. I work in a bike shop and waited till they came out after seeing how simple the Honda rack was and the ripoff price. Forget the wiring, you shouldn't be towing with the Element anyhow (MHO). Hope this helps and saves you all a bundle.
One of the other things you might want to consider about a roof rack is that many people "forget" about the bikes being up there and drive into the garage, thru a drive-thru--much damage to the bikes. I have used a hitch mount in the past with my 4x4 pick-up truck and loved it. Will soon be using one with my E once I install a hitch. And like is stated previously, if you are only going to haul bikes and not tow there is no need to hook a wiring harness.
I tried the bikes inside the E method exactly once, before deciding that I wanted a better solution. To me, the idea of hoisting the bikes to the roof was never a serioous consideration. So, I went the better route of the receiver hitch and am very glad I did.
I got my reciever hitch from :
http://www.hitchesonline.com/honda_cl1_element_03.htm
With shipping it came to just a bit over $110US. It installs very easily in about 20 minutes with just a couple wrenches. No drilling. No hassle.
Then I got a fantastic deal on a 1 1/4" , (2) bike carrier from:
http://www.performancebike.com/shop/cboProfile.cfm?SKU=5176
Again, it bolts to it's foot with just a wrench and you just use a wrench to secure the foot to the receiver hitch mount. The model I got swings down for easy access to the rear hatch, or comes off entirely with a few turns of the wrench. I got it on sale for under $100 for all necessary parts for the rack. It looks like it's off sale, but the price is still right, even with shipping. So, for a total of just over $200, I've got a very versitle class I receiver hitch and a dual bike rack that is much easier on the back and E's paint than the silly roof rack. The bikes can be locked to the rack, and are so easy to load/unload that either of us can do it, even when exhausted from a long trail ride. The hitch is also going to get dual (or even triple ) use, since I plan on getting a canoe loader extension for it as well. This will enable carrying of a longer canoe or kayak or lumber in conjunction with the existing roof racks.
Just picked up my Thule bike rack today. Thank god I have side steps on my E. I am 5'9 and it is a bit of a stretch I think it could be a little tricky if you don't have the arm strangth to lift the bike up or bringing it down.
As for the inside mount it's not worth the money. I lift one seat up and I can roll two bikes in with out taking off the tires. I then bungee them to the side.
I think if you don't have the side steps then the roof rack may not be the best idea
Discussion Starter · #16 ·
Thanks to everyone for your thoughts and opinions....as stated before my hubbie and I are both 5'5.....so the bike roof rack was really out.....We then thought about the hitch mount and the interior mounts.....we wound up simply hanging one of the back seats, drive our two mtn bikes right in....7 bungees later they don't budge....and we are off.
The best part about this method is that we still have plenty of room in the E for cargo (very important for camping trips with the bikes) and the second best thing is that I can personally put my bike in by myself, strap it in, etc. and it is quick and easy...1....2....3.....done and I am off!
I think that if we start seriously road tripping with the bikes than we will go with the hitch mount.....but for now this works like magic!
Dreamscape,
I have a factory roof rack and then purchased the rack set up below. This only comes with one bike gutter so I purchased another one.
The only problem I have is that the front load bar is only 31 inches long. This means that the bikes are not out as far out as I would like. It might be a problem if you are not tall and don't have the side steps. I will take some pics this weekend if you would like.
Send me your email address and I will send the pics to you.
http://www.thuleracks.com/thule/product.asp?dept_id=8&sku=889
I have been riding bike for years. I used to put my bikes on the top of the car and have the Yakima bike rack system. I now putmy bikes inside for these reasons:
1) It is difficult to put bikes on the roof top and not some time or another have one slip and scratch the roof. Even for taller guys like me.
2) If you drive through rain it is not the best to have your bike get wet - it is hard on the gears and and the axles.
3) It is nearly impossible to drive anywhere in the summer months and not get your bikes just coated with bugs.
4) It is quite fuel inefficient - I found that it decreased my gas mileage on my minivan about 10% for each bike I had on the top
5) I like the sense of security I get by keeping my bike inside.
6) If I did for some reason need the room for passengers or supplies I would invest in a hitch system. It would help with the mounting and would not cut down on the gas mileage as much.
1 - 20 of 29 Posts
