1 - 8 of 8 Posts
I am dissapointed when find out that Element did not have some kind of warning light to let you know when light bulb is out. I have to find out my brake light were out from my co-worker when he was driving behind me.
I don't recall any Honda or Toyota I own in the past has warning light for sensing brake light is functional or not.
Do you have any other car did that in the past? :confused:
I cannot recall any vehicle that informs you that a light is out either. Good thing your co-worker told you though.:D
Retired.
Starting with the 1990 models the Accords had a brake lamp failure indicator on the dash. If a brake light was out the light on the dash comes on. Some of the Odyssey models have this as well.
Every GM I've ever owned (quite a few) would warn of a missing bulb by blinking at double speed or higher. Since it's just matching the flasher module to the normal load, I don't understand why Honda doesn't have the same thing.
i have that on our accord. its been on for months, but all the brake lights work. it's off until I disengage the parking brake (with my foot on the brake), then it goes on. The accord boards say there is probably a corrosion problem :confused:
Why'd they discontinue it?
Retired.
I am pretty sure my 2009 Accord has it still.
1 - 8 of 8 Posts
