After cruising through all the threads here on the website concerning cargo baskets, I didn't see anything concerning the issue with the basket itself interfering with the removal of the moon roof glass after the basket has been installed.
I have a basket on mine, but I had to move it as far forward as I could to allow the glass to come out without having to remove the basket as well.
I don't suppose there are any cargo baskets out there that were made to hinge upwards, right?
That would solve alot of the problems with mounting the basket in relation to the moon roof I would think.
You can see how far forward I had to install the basket to clear the moonroof, fyi.
I need access to removing the moonroof to clean the drain plugs yearly, as well as clean off any built up debris on the rubber seal (which can lead to leaks if not maintained).
Be next to impossible to do that without removing it outright.
Is there anywhere to buy body panels to replace the plastic cladding on an 04 Element? I want to replace the cladding with a metallic body panel rather than plastic. I know using plasti dip may bring me close to a metallic color to match the other body panels if I sand the texture away, but id...
I offroad and travel a lot with my E, so I wanted to mount a full-size spare. It's been more than 6 months and the mod is still working great, so I figured I should post to the exterior mods section in case anyone else was considering doing something like this. If another mod category is better...
I just updated my build post to talk about lighting, but figured I’d do a dedicated Fog Light post here since I went through some Foglight pain and show some other options.
I did the Winjets like usual, didnt like the output so converted to HIDs, but those eventually failed for moisture...
When going thru a carwash, I am getting water dripping from the headliner of my 07 SC where it meets the windshild, causing the floor mat on the driver side to get soaked. Also happens during heavy rain. I suspect some sort of windshield problem. Any comments??
The other day I saw some Rhino Liner on the front of a pickup. I must say it looked great. It got me thinking, what If I were to Rhino line the exterior body panels. I have a quote of $300 if I take them off. I wonder...
Weight - would a panel with Rhino on it be too heavy and warp or...
