After installing an Element Roof Rack, I experienced a very annoying wind noise.
Reading the threads on this issue I saw the suggestion to try and change the air flow over the roof rack cross bars.
The cross bars are semi sort of flat, leading edges are sharp with it widening for strength at the middle of the crossbars midsection.
I had considered a fairing, but wasn't crazy about it.
On a recent stop at Casa Depot's plumbig department, I happened on black foam pipe covering/insulation.
This type has a seam along it's length, and each edge has a pull away strip covering it's contact adhesive.
You slide the foam over around the existing pipe, pull off the glue strip covering and the two edges bone together.
Very Expensive $1.69 a 6 foot length (inner diameter would fit a 1" pipe.
So I gave it a try, slid it over the leading edge so that the glue strips would be equally almost cover the entire width the the rack crossbar.
Well today was my first chance at high speed driving to test this out.
Wife and I were on the tollway about an hour when I asked her if she noticed anything?
"Yes, no wind noise." "What did you do?"
I didn't expect her to notice as the wind noise hadn't really bothered her before.
But the bonus is I can put my Yakima storage box right over the foam covered rack bar with no trouble.
Not sure how long this will last in Chicago's winters. But for another $1.69, I can put a new one on each year.
Here's two not so good pics.
Hope it shows better than I could explain.
