couple weeks ago, my E turned the check engine on, i took my E to the computer test but nothing showed up. besides, i've noticed that my E is spending more gasoline since the light turned on.... ANY IDEA??
Welcome, Altklp.
If the check engine light came on (and not the "maintenance required" light), there should be a trouble code stored in the system. You need for a competent person to pull the code from the OBD-II.
Can't say much about your gas mileage issue without hard numbers. You are calculating your miles per gallon, right? But the first thing to do is find out why the check engine light is on.
hi ramblerdan, thx for your reply.....
ill take my E to another computer test tomorrow and post the results,
thanks again!!
AF sensor or O2 sensor tripped and now it's running rich. Mine was caused by an exhaust leak. Should be an easy fix.
