My check engine light is on; 110k miles......could it be o2 sensor? To the best of my knowledge it's never been replaced.
Could be...My check engine light is on; 110k miles......could it be o2 sensor? To the best of my knowledge it's never been replaced.
Nope, not the gas cap.Could be...
Also could be a loose gas cap or an evap system fault or a vtec fault or a VTC fault or or an IAT fault or an ECT fault or a TPS fault or a camshaft phase error fault or a transmission fault or it could be.....
Hey, here's a wild idea!
Instead of guessing at what it could be, how about getting the code read?
Wouldn't that almost make sense?
OK, so replace the O2 sensor.I've owned 5 Hondas and each time the check engine light has come on it's been the o2 sensor.
^^^THIS^^^ Because having your own basic code scanner is just one of those tools that somebody should have if they do any basic maintenance/repairs on their own vehicles. Plus it can save you hundreds of dollars in unnecessary shop visits.or you could buy a code reader with the $90 the shop wants to charge you. ;-)
Hey thanks Slimer...i might have to take you up on that. Ill keep in touch and let you know.Hey if you wait around for next Thursday I have a reader and will be down there getting some stuff at the airport and could check your code instead of guessing or you can go to Craigens or Auto zone and you can get it read for free and also Aamco does the same thing.
