Actually I didn't run that wire under the upper molding,I ran my video signal wire through the factory grommet located on the left side of the upper hatch,then I removed the back seat and the entire side panel to run it to the front of the vehicle.If you're wanting to remove that plastic headliner trim piece that houses the rear dome light,you will need to pop the lens cover off the dome light and remove the two screws that hold it in place.Then you'll be able to safely pop that trim piece off.Oh and after you pop it off just unplug the dome light.how did you run the video wire to the front under the upper molding? i looked at the molding, but don't know how to get it off without total destruction of either the headliners panels, my hands or both does it just pop off with a wide thin blade underneath?
i have a camera , and being in the NE, i will use probably use the rear lock hole.\ i want to get the rear video wire up front, so i can do the same as you , mount a switch for anytime use.
i will probably keep it temp mounted, till i am sure where it will work the best. i tried the camera at home, and it has a wide angle lens, hopefully from the lock hole, it will pick up the bumper of a car while parking, and full view for people.
i saw a Magellan 7 inch gps, think it was a roadmate 1700 that costco has on sale. It has aux video jacks, and may buy that if i can find a good mounting place/
main question is getting a nice video cable run.
A while back I did a little searching for another member who was also interested in that camera and this particular camera looks to be the same one that I have.@ Eww-an-E, I clicked on the link you gave to the ebay page where you purchased your camera but it had expired. Could you give me the specs on the camera? And, do you think that instead of using the windshield wiper hole you could get a better angle by drilling a hole and mounting it down by the license plate?
I have no idea if it will fit, but it wont work. The video format for that camerawill this ebay backup camera selling for ($9.79 +$5.99 shipping) fit at the rear wiper?
http://cgi.ebay.com/3-6mm-Wide-Angl...tem&pt=LH_DefaultDomain_0&hash=item4aa1f9ac78
Thanks and as racerc2000 mentioned, sure you could probably do that if you were to find the correct wires.Awesome, totally streamlined. Now, could this camera be powered on and off by the same stalk switch that powers the rear wiper motor? Maybe fed to the head unit through an Aux port if available to bypass the only on in reverse mode?
That's a top 5 mod EASY. Congrats on a great idea, and clean install!
