So I've notice for a week I've been smelling a chemical smell when I have my ac on smells like freon and want to k ow if this has happen to anyone I'm assuming it's a leaking or cracked heater core
Could be coolant leaking from the heater core connections.
Keep an eye on the coolant levels, could explain something.
2007 Element EX AWD AT (two!)
If the heater core is cracked, you would be smelling coolant (anti-freeze). If you think you're smelling Freon, it would be from the evaporator. As insider suggests, keep an eye on your coolant level. If your AC starts to not cool very well, then have that system checked for leaks.
Ok that makes better sence now I changed my cabin air filters the other day and the smell is gone but curious if the filter are just masking the smell
