2004 Element 5 speed and the the clutch must be pressed all the way to the firewall to engage the clutch and it seems to be fully disengaged when letting it out a mere 1/4 inch. How do I adjust the clutch throw so that it's more normal? At times it can be difficult getting it into gear unless you really lean on the clutch pedal and get it all the way to the floor. Or is this indicative of some sort of an issue? Thanks for the help.
I checked it fairly recently. The problem seems to be getting slightly worse over time. I'll check it again. It may be the clutch going bad.
Does anyone have a picture of the clutch master cylinder on the element, where it is in the engine bay? My daughter has the car in Orlando and there is no way to talk her through this without a picture. I've looked online for one so far no luck.
as far as I know, yes!
Unless Honda calls for some special type of brake/hydraulic fluid.
