Anybody research cold air induction for the E yet? What about performance mufflers? ( I want to leave my catalytic converter intact) What do you think the extra 15-30 ponies would do to the 4 speed automatic? I did read that the frame and layout of the E does enable it to handle more then stock power. I would love to give my E a slight "edge". I do mostly highway driving and don't beat it on. I would like as much power as I can get for merging and passing, It wouldn't hurt
I think that more power is critical. I am considering an aftermarket nitrous and supercharger setup to pump some viagra into the little 4 banger. Also, I would like to customize the rear of the Element with a headlight and grill package that looks identical to the front of the E. i would call it the push me pull you!
Nat,
Mabey I can be of a little assistance. We all know the E is slightly lacking in the power department. I will refer you to this website. They dont really have Element specific equipment. But they do have universal exhuasts that could deff be mounted to your ele after the cat.
Also they have performance modules that will work on your ele. I work closely with the guys that run the place. They are in the works of making a unit similar to the Venom 400. This would fix your transmission up to a more sport type shift point as well as increase your power. Check them out when you get a chance, Mention this post and Im sure they can give you a discount.
www.advancetiming.com
