OK, I’ve read the mod on how to make the rear outlet always on with the relay removal and jumper fix: http://www.elementownersclub.com/forums/showthread.php?t=6994
I’ve also read how to permanently install an inverter in the E by reading this golden oldie from E-Shen: http://www.elementownersclub.com/forums/showthread.php?t=3792
I need to do both of these mods because my E is now my mobile office. I’d like to use the removed relay that controls the rear outlet to protect the inverter.
Is there any way to move the relay to the empty slot available on auto transmission E’s and then wire the inverter to that? Any idea if that relay spot is protected by a fuse? That might also eliminate my need to do an inline fuse.
The reasons I ask are that I’m an electronic idiot, I have limited time to get this done and if I’m going to pop the glove box, I’d like to get all my wiring done at once.
Here’s the link to Rambler Dan’s relay diagrams I’m using to base all this on: http://www.elementownersclub.com/forums/showpost.php?p=78673&postcount=14
BTW, I bought a 400w Black and Decker modified sine wave inverter.
