[quote:cbe6cad960="Tygh"]I put Infinity components in my EX. Ended up taking them back out as the tweeters were way to tinny for my ears. Very harsh. I am going to work on a different configuration, which will most likely result in a different head unit as well.
[/quote:cbe6cad960]
I hear that. Infinity is known for notoriously bad highs.
If you find most tweeters too tinny (aka bright) in general then you should consider silk dome tweeters instead of metal (which most tweeters are made from) since silk produces a much softer, warmer high.
My personal recommendation for a reasonably priced great sounding component set with silk dome tweeters is made by a company called Crystal Mobilesound. Street price is about $175. Check em out here...
http://www.crystalmobilesound.com/componentdetails.asp?ComponentID=2
BTW, the web page lists the model as CSc 60 S/T - just so you know the S/T represents the tweeter material choices...
If you want the silk then order the CSc 60 S
If you want the titanium then order the CSc 60 T
