1 - 8 of 8 Posts
Hello, I am considering buying a quicksilver 10.0 to tow with my 03 E. The trailer's dry weight is 1020, but will a/c and accessories, I'm guessing I'll be closer to 1300 pounds.
I am planning to drive cross country this summer with this set up, and I'm nervous about killing the transmission on my car. Any input? Should I install a transmission cooler (it doesnt have one - I looked)? Or would it be adequate if I change the fluids right before the trip?
Melanie
Thought the E had a tranny cooler? I think your going to be fine pulling that trailer!
Yes the E has a built in tranny cooler...(if you have an automatic transmission)
have a look at the trailer thread, and see what everyone else is pulling...
You should have no problems with yours
I built this camping trailer, and it tops out at 2,000 lbs. The trailer is equiped with electric brakes, the E has a class 3 hitch, new "heavy" duty tires, and the largest rated transmission cooler that will fit. The brakes on our E are in spec, brake fluid is clean. The shocks were replaced at 60K before towing the "Towster".
The E is rated at 1500 lbs max. I can tow this trailer with ease. I have full confidence when towing because it stops easily, and I drive defensively. Your results may vary.
http://www.elementownersclub.com/forums/album.php?albumid=395&pictureid=1920
1 - 8 of 8 Posts
