Hey folks, did a valve adjustment and oil change 1000 miles ago (here's that thread: Cleaning after Valve Adjustment) and did an oil change this weekend to be extra nice to engine and see if anything was wrong after the adjustment.
Well, my oil looked like this when it came out:
Is that coolant?
I checked the radiator, and it looks like this:
A little sparkly/shimmery, but not chocolate. Is that metal shavings? Or a tiny bit of oil? Or does the coolant look okay?
I've been searching the forum and have picked up lots of good info, but I'd still love some advice for my specific predicament.
Here are the full details:
Is that coolant?
- 203,504 miles: I did an oil change. The oil came out looking very dark, but I didn't notice any opaqueness.
- 204,804 miles: My water pump broke, and I replaced it.
- 208767 miles: I did my valve adjustment. After closing everything back up, I drove around the block then did an oil change. The oil came out looking very dark again, but also, didn't look opaque.
- 209786 miles: The oil change from this last weekend.
- The engine temp on my dash has been extremely steady (after the car warms up) right under the halfway mark through all of this stuff.
- The coolant level in the reservoir seems much lower than when I replaced the water pump and refilled the radiator. It's moving around though... It was below the minimum mark last night, but this morning it was above the minimum mark, and I haven't done anything to car.
- Is that definitely coolant in my oil?
- If yes, do I definitely have bad head gasket?
- If yes, can I replace it myself or would I need a machine shop to level something off?
- Could the valve adjustment have somehow caused the dirty oil, even though I change the oil after doing the adjustment? Or could I have caused an issue with the head gasket during the valve adjustment?
- And this one's subjective but I'd appreciate thoughts if anyone would like to give them: How worried should be? Do I need to start saving for a new engine, or can my E handle a little dirty oil just fine if I've caught it soon enough? What are the warning signs I should be looking out for that I've done some serious damage to my engine, and is there a way to know how long there's been a problem?
