1 - 13 of 13 Posts
Don't Let This Happen To You!
Well dopey me, I torqued the screws a bit too much and cracked the deflector at the two outer screw locations :oops: . I swear I was careful...I really didn't think I turned them that hard. Maybe a rubber washer would be a good idea. Or at least a note in the instructions for us gorillas. Anyway I dabbed some clear epoxy at the ends of the cracks on the inside of the deflector. I thought about poking a small hot nail through it at the ends of the cracks to stop them but the epoxy seemed easier.
So don't you be turning those screws too tight, y'hear?
KenBob.............at least your screw up was a lot cheaper than mine! I drilled a hole in my condenser to install brackets to the bumper bracket to hold the custom bumper guard. No cheap way to fix that muck up!!
Ger
I did the same thing installing my deflector. Only one though....the last fastener I did cracked. Can you spell PISSED.
Now I wish I had ordered it with the Element, then I could have bitched to the dealer...
KenBob:
I just hate it when something goes wrong when you're screwing!
:lol: :wink: :!: :shock: :p
Don'tfeel bad guys, I did the same thing as well, a small crack on the right hand side. I thought that the little white insert would prevent this from happening. It's been on for a week and the crack did not grow yet.
[quote:5562747575="ERider"]I did the same thing installing my deflector. Only one though....the last fastener I did cracked. Can you spell PISSED.
Now I wish I had ordered it with the Element, then I could have bitched to the dealer...[/quote:5562747575]
Wouldn't some Super glue be perfect to fix it? Sounds like a perfect fit for Super glue. You have a small crack with matching sides. Unless there's a void there it should be a permanent fix and stop the cracking.
I just installed mine and have notice the small crack on the left side, i follow the installation instructions very closely. I don't know what I did wrong?Lightly fited all hardwares, didn't over tight the screws.
Would Honda Accessories exchange for a new one, have anyone tries to return it? :cry:
[quote:94d035ae01="Slowhand"]Wouldn't some Super glue be perfect to fix it? Sounds like a perfect fit for Super glue. You have a small crack with matching sides. Unless there's a void there it should be a permanent fix and stop the cracking.[/quote:94d035ae01]
I don't think super glue would do it, in order for the glue to work the surface where the crack have to have glue on it. Beside super glue make a mess on the smooth surface and melt or deform surface too.
I am joining the cracked air deflector/bug guard club....it arrived from H and A today and I went right out and installed it.....did everything by the instructions, and was even extra cautious due to this very post, but still as I was putting the last screw into the side bracket on the passenger side...crack, and the screw wasn't even flush with the air deflector when it cracked....I looked down as I heard the crack in total disbelief.....oh well!
I will probably be the only one who notices, I am not even going to mention it to my husband unless he says something :wink:
I do like the look of it, but the real test will be once I hit the road!
You mean these deflectors aren't made from polycarbonate ???....now that is a waste of money....I mounted on my previous car some wind deflectors made of I can only guess it was tinted plexiglass that once under little pressure these cracked........later I bought this wing ( rear air deflector) and asked the salesperson about the material and he said polycarbonate....and after installing it it went 3 winters with it, it survived the weight of the snow on it and the many times I applied pressure when I washed the car.........here is a pic of the rear deflector just to show you guys....and thanks for the info...I will contact the same place I bought the deflector ...maybe they make one for the E.............
(the deflector is the part above the rear window... :roll: :wink: )
1 - 13 of 13 Posts
