Good Day! Well, Rainy day here in Las Vegas, but Anyhow...
Check engine light came on in my 03 Element, took it to Autozone to find out why.
Code came back as:
Cylinder number 1 misfire with possible causes: 1. Vaccum leak affecting one cylinder 2. Ignition System Concern 3. Blocked/Faulty injector 4. Engine mechanical Condition
So, I changed my plugs, assuming this might be the issue as I have had it since April 09' and never changed them. No luck. Decided to move the injector coil from #1 to #4, thinking this would tell me if the injector coil was the issue. Light came back on. Took Ele to Autozone once again to have the light checked. Now im getting a misfire in #1 and #2 with nothing about #4.
Got back home and indivually unplugged each chip from the injectors, same sputter with each injector.
Looked at all lines to/from the intake maifold with no visible leaks.
HELP... once again:twisted::twisted::twisted:
Code came back as:
