This site lists them. I think this is their main site.Well I stand corrected. I even searched them on Google & found what I thought was their home page & they had no listing for the Element. http://www.d2racing.com/content/products/RS_coilovers
did you order the bearings from ks or are those the stock ones?add bearings to the front spring perch to get rid of the pop when turning which I added to my ksports.
Where do the bearing go? Do you have pix of yours installed?No, KSport does not carry them, I had to go to a bearing supply place and custom order the size, I can get them for anyone, just takes a couple weeks and is $40 a set plus shipping.
Are you really in Hayward, CA??? I grew up there. Im in Fremont now. I wasI just received this set today from D2. (D2H126) I will post the results once I get them installed. The front springs are 10k and the rear are 13k. Not sure yet If I need a 15k rate for the rear. I had extended my rear top hats 1.75 inches.
When I bought mine it had a TEIN set-up with 12Kg/mm installed. 12 was WAY soft. I replaced it with 14Kg/mm and while it is much better it is not too hard, and when loaded may still bottom out.... If you have a 15Kg/mm option, - DI IT!!...........the rear are 13k. Not sure yet If I need a 15k rate for the rear. ............
I will be posting results on the new springs within the next 2 days. Also, the front spring pop is not really an issue or problem, it only happens at really low speed tight turning, it is easily fixed, go buy a set of skunk2 or top speed coilovers, they pop to the point you think the front suspension is gonna fall off, I have heard them both, the ksports are very small compared to others, do not let a little pop turn you away. I just drove 1300miles in 22 hours and the KSports held up to the worst roads I have ever seen, I am impressed.Bump! waiting for the D2's outcome...I'm still debating with Ksports with the rear springs issue and now the popping noise. :roll:
