Update on successful wedge fix
Thanks to this site and a youtube video showing how to remove the instrument cluster, I was able to fix my suddenly dark instrument panel in about fifteen minutes.
My panel went dark a few weeks ago and I assumed it was bulbs. On reflection it didn't make sense that all bulbs would go out together. Only the needles and odometer remained lit. After finding this thread I was quite sure I had the same problem many of you have described: loose main connector.
I decided to try out the "wedge" fix for the larger electrical connector on the instrument cluster. Easy to pop the fascia off and access the cluster with a flat screwdriver to pop off the side fascia and philips screwdriver for main shroud and instrument cluster. I first pressed up on the larger connector and determined that pushing it up did cause the instrument lights to work. I then took a 30x20x3mm piece of rubber/silicone from a set of car mats and wedged it into the slot below the connector. After checking that it made the lights work, I then ziptied it into position around the connector.
Took literally fifteen minutes including a minute or two hunting in the garage for an odd piece of material to use as the wedge.
Photos show rubber piece installed and the source of the rubber section.
Thanks guys.
Thanks guys.
