1 - 8 of 8 Posts
My console has begun to separate itself where the arrows show. I will need to disassemble the console to fix this. What is the process of the tear down of the console?
if you pull the cup holder out there is a 10 mm bolt under it. then that whole piece yanks out.
The entire center piece removes with only that single bolt?
I'm also going to wire some LEDs into the underside of the front area of the console to glow over that lower shelf area--will I be able to access that area once I remove the center piece?
1 - 8 of 8 Posts
