1 - 12 of 12 Posts
EDIT:
This mod will work as listed for all 2003 - 2007 model Elements.
An important note:
This mod will most likely cause some concern for, if not invalidate your warranty if something happens to the Multiplex Control Unit (MCU). I have no idea how Honda would respond to anyone who does something to damage the unit. I urge anyone who is weak at heart or lacking in electrical skills to be aware that while I'm sorry if you totally trash your MCU it's not my fault so don't start whining at me if you screw it up.
In other words, yes this circuit modification works. I have it installed in my E right now, but I have no control over your abilities to build and/or install this modification. Therefore, proceed at your own risk.
The problem:
Lack of adjustable delay sweep when the wiper is in the INT function. Depending on your situation, the OEM delay of 7 seconds may be too slow, or too fast. Ideally there should be a method to adjust the delay to suit the situation. The desired solution should be as minimally invasive as possible, and yet functional. The other functions of the wiper should remain exactly as the OEM designed.
The Solution:
Build and install a small time delay circuit board. Use the new delay board to control the sweep of the wipers while in the INT function.
In order to simplify the instructions, I will use the following colors when describing this mod.
“Delay Timer Mod Board wire color”​
Wire Color_______________Schematic Notation
Red____________________Switch Pin 13
Black___________________Ground
White___________________Switch Pin 12
Brown___________________Under Dash Fuse/Relay Box B6
Parts List:
The following parts are necessary for construction:
1 – small perf board an example
1 – small plastic case (I did not want to drill any holes to mount the unit) an example
1 – 12 volt DC relay SPDT (20 amp contacts would be great) an example or this one would work too.
(Resistors can be bought about anywhere, but you can get enough right here for ten of these boards for $2.00)
1 – 3.3k ohm 1/4w carbon resistor
1 – 10k ohm 1/4w carbon resistor
1 – 47k ohm 1/4w carbon resistor
1 – 100k ohm 1/4w carbon resistor
1 – 100k ohm potentiometer an example
Note: if you are wanting to drill a hole and mount this in the dash, I would recommend this type of pot.
1 – knob for whatever type potentiometer you choose.
1 – 2N3906 or equivalent PNP transistor an example
1 – 2N2222A or equivalent NPN transistor an example
1 – 1N4002 diode or equivalent rectifier diode an example
A few lengths of AWG 18 hook up wire. The exact length is going to vary depending on the location you decide to mount the unit. Regardless, the wire is available about anywhere. I would recommend you have different colors (I will use red, black, white, brown as the wire colors in this document) to prevent errors both now and later on.
Parts availability:
There are numerous sources for the components, I use these guys a lot and recommend them. However, these should not be considered the only source for components. Remember, some of these have minimum order amounts and are not the best for 'small projects' like this.
Mouser Electronics Digi-Key Electronics Newark Electronics
If you're looking for some bargain pricing I have to say, All Electronics would be one of the best for 'tinkering' and 'project parts'.
Assembly:
First, let me say right up front – I do not recommend anyone without basic electronic soldering skills even attempt to build this circuit. I'm sure you can locate a 'hobbyist' or technician who could build the circuit for little if any cost. If not, contact me and we'll work something out.
With the above said, I will not go into any techniques of assembly, other than to refer to the above schematic.
Installation:
Disconnect the negative terminal of the battery. Be sure you know the code for your radio, and also how to reprogram your automatic window. You will need to reprogram the drivers automatic window and reenter the radio code when you reconnect the battery later.
There are a total of four wires that will be involved in the unit.
I opted to make the connections at the Under Dash Relay/Fuse box. It just seems to be the easiest to get to. There are two connectors that we will use, connector B located in the upper right corner of the front of the box, and connector X located in the middle left side on the back of the fuse/relay box.
The power source is the INT output from the switch pin 13. It is the blue wire with a black stripe in the X connector. You need to cut this wire, connect the red wire to the harness, and tape off the bare wire that goes to the connector at the fuse box.
The next connection the Blue wire with the red strip in connector B. Cut this wire, connect the white wire of the delay board to the wire from the switch (harness), then connect the other end of the wire (that goes to the connector) to the brown wire of the delay board.
Then connect the black wire from the delay board to a suitable ground. I used the one just visible above the center console if you look over to the right from the fuse/relay box.
I opted to put the whole board into a project box and attach it to the dashboard of the Element with double sided foam tape. If you desire, it can be mounted under the dash anywhere and a panel mount pot mounted somewhere on the dash. It would give the mod a more professional look. But you would have to drill a hole in the dash.
And just for fun, a video of the delay in action:
Clean up the loose ends:
Reconnect the battery, enter the radio code and reinitialize the auto window.
Go grab a beer and wait for the rain... ;-)
yeah, you're an EE.
bh241, Great write up :cool: , mite have to do this mod, thanks, Tim
Nice work !! Thanks !!
I have been thinking about doing something along those lines.
Justin and I were talking about this, the week before last. I was thinking of using an IR Emitter/receiver on the dash looking at the swept area of the windshield. No refraction when wiped, then refraction when wet. I have not worked out the trigger circuit at this point. It would fit in on your print just before the SPDT. I was thinking that the intermintent on the tree could be left in the on position. The system will only become active when wet. I did want a way to disable it for a car wash. So using your method may be more feasible.
Dom
I thought you may wish to see what peaked my interest in this mod. At first I was going to build it to put up the top on the wifes MB 500SL in case of rain.
Then thought about adapting it to the E's wipers. I was waiting for a report from the Below link, that never came. They do produce a product for sale, It's price is slightly over 2,000$. Too much money to wipe a windshield.
I did some other research as well, One of the links on a ham sight has been taken down. I had printed the schematic, I thought I filed it in the Mods folder. NOT !
Oh well I will come up with something!
http://www.cse.psu.edu/~cg430w/memo2Buben.htm
Dom
Discussion Starter #6
I like the idea, but with as many bugs that commit suicide and then smear all over the windshield around here I can't help but wonder if that would be an issue...
Don't get me wrong, I'm not saying it couldn't be done... must get that notion out of my head.... :???:
If you notice there is an area about 1 inch above the wiper that does not get hit that frequently. In fact, a study by Land Rover, showed it was free from Insect strikes, more than 95% of the time. So that's what there Ir sensor is aimed.
That will also be the best point of aim from a sensor mounting prospective.
Dom
Mod-erator
Very nice mod!:D ....I remember some guy about 10 months ago complaining that the wipers needed more settings :rolleyes:
Dan thanks for posting the files!
Discussion Starter #10
It works with the 2007 model
I just had a 2007 schematic sent to me, (thanks Gambling element) and this mod will work as posted with the 2007 models. :)
Anyone made one yet?
If you want one, and are afraid to build it, get with me and we'll work something out.
Personally, I like having this more and more. It's just one of those things you are use to having and miss when it's not there.
works great but a simple problem
i did this circuit to my santro. which one it doesn't have intermittent wiper speed
it work great - thank you very much
problem is, relay switch works good but wiper misses every even click of the relay switch,wiper motor just jurks and stay still on every even clicking and wiper wipers every odd clicking, may be its because of the delay time between the circuit connected and return to normal in the relay switch. could you tell me which resistor(s) to be added to increase the delay time (mil sec) of relay switch to stay connected before it return to normal?
1 - 12 of 12 Posts
