For those of you who are having the Bad or Ugly, maybe poor THROTTLE issues or the dreaded 1K Idle bouncing? Then get stuck at over 2K and up Idle. Try checking for vacuum leaks then try cleaning your IAC value before you go and buy any parts....and for those of you who can't get past 3-4K RPM's it's likely your sensor assy map connection or the unit is having issues.
Quote given was - $2300 parts & labor, plus one day in the shop time.
Gauge Tacking from 400 - 1500 rpm continuously..
Code P0505
-vacuum leak
-DIRTY THROTTLE BODY
-IAC motor defective
-Poor electrical connection to the IAC value
Now, SO lets try my easy option before anything else is done......
What you will need
-10mm socket
-12mm socket
-Philips screwdrive
-Dremel or file
-2 Claps or Zip ties
-1 Carb/choke/throttle body cleaner
I used 2 Carb cleaners, one the cans was from HONDA
-2 Micro fiber cloth
Cost - you shouldn't have internet if you can't afford this.
Time - 2 Hour, or maybe 1 Hour ( I went over Kill on this ).
First things First
DISCONNECT YOUR BATTERY!!!!!!!!!!!!
Step 1
Locate your THROTTLE BODY (TB).,
Step 2
Remove the sensors that are on top of your TB, total of 3, along with the connections on the bottom side of your TB.,
Step 3
Remove the Throttle cables.
Step 4
Remove the 2 bolts and 2 nuts that hold in the TB, they are located on all 4 corners of your TB. Try to pull the TB off, if it doesn't slide right off use more umff and maybe a rubber hammer with gentle taps to pry it off.... BE CAREFUL to not break your gasket!!
Step 5
This is where you need claps or Zip ties... the only thing that is stopping you from taking the TB out is 2 hoses attacted to the side of it. There are little crimp claps holding them on, release those, hold onto a hose and pull it hard. Once the hose is off clamp the end to avoid fluid leaks.
Step 6
Your TB should be removed, if not you took off the wrong part.
Step 7
Time to remove your IACV, 2 screws, hold it place.,
Step 8
Now that we have what we need to clean off, its' time to whip out the Dremel. Cut a line into the safety screws.
YOU MUST REMOVE THE SENSOR BEFORE YOU CLEAN!
Step 9
Time to clean... put the black sensor off to the side so you don't get anything on it. Take your cleaner and spray into the vave. Don't worry about how much to use. Just clean all the S$$t out of it and make sure that it can spin freely and smoothly when you're done.
THIS IS THE ONLY THING YOU NEED TO CLEAN!!
But, I did clean the Throttle Body also.
Step 10
Make sure your IACV is clean and completly dry. Test spin it. If it's not moving fast and smooth then ---- RE - Clean ---- Again!!. Plus, a few drops of 3inOne oil into the bearings will do the trick. Or not and risk seizing up the bearing and you have to purchase a whole new IACV assembly. You can't just buy the part, unless you get one off 3rd hand.
Step 11
Assemble your TB completly, when you put the IACV back on make sure it looks this one... the valve can go on the wrong way.
Step 12
Put your TB back on and reconnect everything. Reconnect your battery and start your engine. I REV'ed my enginge for 5 min's untill the fan came on. I closed the Hood, then took a drive into the Mountains with a new car feel. I stoped at Costco for Pizza and a Hot Dog.:lol:
I'll fix pictures later.
Code P0505
-vacuum leak
What you will need
-10mm socket
-12mm socket
-Philips screwdrive
-Dremel or file
First things First
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
