I have a 2003 element ex awd auto and I want to get more performance out of it
Also how much more performance? If it is a lot more then yes forced induction would be the way to go. Of course the other big question is how much time and money can you afford to throw at improved performance?
[/QUO
No no. Nothing too crazy like turbocharging or forced induction. Just looking for a bit more torque and H.P. around 5-10 hp and 5-10 ft of torque. Reason being is when I’m on the interstate and traffic is going 90-100 mph, I have my foot to the floor when I’m at 90 mph. It slowly creeps up in speed after 90 mph. I think a few more horses and torque could be useful. Question is how can I gain more power without going full blown crazy missing the element. Also they claim the top speed is governed 110 mph? Find that hard to believe. It struggles at 90-95 mph! I hate that
Start looking at the performance threads. I have done many mods starting off with intake and dyno tune all documented on this forum throughout the years. You will not be able to notice a 5hp increase. HP gained from bolt on's will be minimal gains at very high RPMS without tune. The joy factor for me though was priceless. If you just want to have fun and mod your E then go for it. Injen exhaust is quality.I have a 2003 element ex awd auto and I want to get more performance out of it
Thank you that would explain why the twin turbocharged car I had made more power. It had a Mass Air Flow SensorThe Element has a MAP sensor (manifold absolute pressure) to control the air-fuel mixture. It can't really tell that the airflow has been increased by a ram air intake with a K&N filter. Cars with a MAF sensor (Mass Air Flow) can sense the increase of airflow and automatically adjust the fuel ratio to eke out around 3 to 5 more hp.
FYI, the 07 does have a MAF.The Element has a MAP sensor (manifold absolute pressure) to control the air-fuel mixture. It can't really tell that the airflow has been increased by a ram air intake with a K&N filter, the intake could alter the manifold pressure in weird ways which could throw off the MAP sensor and cause worse performance. Cars with a MAF sensor (Mass Air Flow) can sense the increase of airflow and automatically adjust the fuel ratio to eke out around 3 to 5 more hp.
OP has a 2003.FYI, the 07 does have a MAF.
For giggles, I measured the restriction of the stock air box with a well used factory filter. Have a gauge that measures vacuum in inches of water column. Full throttle at redline, it showed 4 inches, that's like .14 of pounds per square inch. So, in reality there could be no significant increase in air flow.
I've kept filters out of the landfills too... Mine is the original factory filter 2007 with 93,000 miles. No plans to change until the filter minder trips a restriction.I also found that I hated cleaning and re oiling the K and N filter at pretty much every oil change. However at least it helped to keep so many regular filters out of the land fill
Thank you for being straight up about that. I never believed that my engine air filter needed to be changed as often as was recommended especially if you could remove and blow out alot of the dirt that had accumulated in the filter. I have never noticed decreased performance or fuel economy on an old filter with 20k kms on it.I've kept filters out of the landfills too... Mine is the original factory filter 2007 with 93,000 miles. No plans to change until the filter minder trips a restriction.
Dirty filters actually filter better than a fresh new filter.
Here at the dealer we are forced to change filters during routine services. Most times with only 20K on them, it's hard to tell the new one from the old. It's really a shame the amount of waste generated here.
Can you please explain how dirty filters clean better than new?I've kept filters out of the landfills too... Mine is the original factory filter 2007 with 93,000 miles. No plans to change until the filter minder trips a restriction.
