Not sure if this is correlation or causation. The other we noticed that door ajar light will not go off not matter how many times we close all the doors. Normally this would also turn on the dome light but our wonderfull dealer (Honda Santa Ana) removed the dome light when they installed this POS DVD player, thanks guys!
A day or two after noticing that door ajar indicator light is always on the E's battery was toast. Not sure there is some small draw even though the dome light is not on.
To diagnose the door ajar light issue I have
1)With the ignition on, I have pushed on the doors and closed them aggressively
2) Removed and cleaned the switch sticking out of the clam shell (suicide) door
3) Grounded out the connector which goes to switch on the clam shell (suicide) door
4) Attempted and failed to find the connector mentioned here
How does the button on the clam shell (suicide) work? I might have been testing it wrong, is the wire grounded when the door is open or closed?
We need this car up and running, I'll be replacing the battery tonight and I can't get the door ajar light fixed ASAP then I'll have to pay out the wazzu for the dealer to fix it.
thanks
thanks
