Hey All. I just got a 2004 Honda Element with key less Entry. Immediately noticed that the Door Ajar light is on often, whether doors are open or not. The reason I mention the key less entry is because if the door sensor isn't working, it shows the door is open, and wont lock via the key less entry. Anyone have any ideas? Is this common? Let me know. Thank you!
If it is the side door light, does pressing the rubber covered button on the door jam make a difference (either side)?
While you are looking around the doors, make sure the sticker plate in the door sill is not loose. If loose that could affect how snug the doors close. Worse if you loose screws there spells big trouble.
The door light and key less entry issues are probably due to the same problem.
Hey, I appreciate your help, and I'm sorry for the delayed response. I never received a notification that this thread was replied to. I found that the door jamb thing was loose, I tightened that, but the key less still isn't locking. I have to put the key in the door to lock all the doors. Any ideas?
