I have to lock my car my using the key. If I use the key fob the lever doesn't go down. If I try to force it down, it doesn't budge. Is there any easy fix for this or is it a major PITB?
Thanks I will do that.See this thread, stickyed in the Do-It-Yourself / Mods section. This might enable you to see what's wrong in there.
Is the door open or closed when you try to lock it?I have to lock my car my using the key. If I use the key fob the lever doesn't go down. If I try to force it down, it doesn't budge. Is there any easy fix for this or is it a major PITB?
It's closed.Is the door open or closed when you try to lock it?
It needs to be closed to lock.
Compared with my car....yes.Is this out of the ordinary?
