Greetings,
I am hoping for some advice in isolating a problem with my power driver's side window. After putting the window up, it would not go down. When activating the switch to the down position there is no click at all, but when moved to the "up" position one hears a relay type click. I removed the door panel (many thanks to earlier threads) in hope of a loose connection but no such luck. I have reviewed the threads and am still uncertain if this is a switch or regulator problem. I come to the mountain seeking wisdom....any advice on how to discern which part I need?
Many regards and thanks in advance.
Fred
Fred
