I'm not trying to be mean and I know answering the same questions does get tedious, but in the time it takes to complain to someone about searching or their lack thereof, we could offer help or point them in the right direction or even do something as simple as post a link.
Once the door panel is off, the window regulator is basically a reverse-is-opposite-of-removal procedure. Just look carefully at what holds things on and if you have to, write down or take digi pics of the removal process. A lot of things at work here regarding doors I do without the manual unless I'm not sure where a fastening bolt or nut is for the door panel (don't want to yank too hard thinking the clips are just tough and there's still a screw or bolt in...ask me why
:lol
The only "special" tools needed (Honda calls them that in the manual) that I know off are basically plastic trim panel tools but they can be easily replaced with a small prybar wrapped in tape to protect the paint. The door panel comes off quite easily once all fasteners are removed and it basically clips in.
The tough part about the regulator is fishing it out from the door. You have to tilt it at certain angles to get it out but if you take your time and work slowly and carefully, it is definitely do-able in the driveway or garage.
