The driver's side power window works fine but when I click and release the switch, the window just stops.After battery disconnect, power window auto-up/down function inoperative
I recently installed the keyless entry on my new Element. However, I have one small problem - the auto up/down function on the driver's window is disabled. Can anyone help me on this? Thought I read a thread in one of the forums about this but can't find it now.
Any help will be appreciated. Thanks!!
I recently installed the my ip birthday wishes tneb keyless entry on my new Element. However, I have one small problem - the auto up/down function on the driver's window is disabled. Can anyone help me on this? Thought I read a thread in one of the forums about this but can't find it now.The driver's side power window works fine but when I click and release the switch, the window just stops.
Oh yeah, many a time you just need to pop out and back the power window fuse. It's either # 6 or 23 I can't remember. You want the power window relay I believe it's a 7.5ampI installed the Honda fog lamps last night. Everything went fairly well but I noticed today that the automatic power window feature doesn't work!
The only thing I can think of is either I accidently loosened a connector around where the relay resides or I have a defective wiring harness.
I'm going to debug it tonight and hopefully find a loose connector. I cringe at the thought of replacing that harness; it was a pain to install.
Has anyone else had this experience?
No, but if you read the rest of the thread first or use the search function, you'd know that all that's needed is to run the window down and hold the button for a few more seconds - then up and hold it again like before. This relearn process needs to be done every time the battery is disconnected and is probably one of the most asked-for problems on the board.Oh yeah, many a time you just need to pop out and back the power window fuse. It's either # 6 or 23 I can't remember. You want the power window relay I believe it's a 7.5amp
