I have a canadian Element with the DRL's installed from factory. I recently installed a HID kit with motorized HI/LO bulbs. After install my DRL's quit working. The DRL indicator lamp comes on the dash also. My HI/LO beams work fine. When I release the park brake they turn on and then shut off. I checked both drl fuses and they seem fine. The HID harness has a relay that I thought might be the culprit, but the manufacturer told me that if the relay was defective, the lights wouldn't work at all. The only other thing I can think of is that mybe the HID plug. that connects to the factory bulb plug, is wired incorrectly, therefore the polarity is wrong. When I turn my drl's on and check the factory plug with a test light, none of the 3 prongs have power to it. Is this just because the voltage is so low? Any help or suggestions would be great. :-(
