It seems my bright light indicator comes on when my lights are on and my right turning signal are on at the same time. If you pull back the lever just a tiny bit...it goes away. But it pretty much happens every time unless you pull back the stalk. This isn't the bright lights coming on...this is just the indicator as far as I know...the stalk is in the regular beam position...just seems the bright light switch is a bit too sensitive. Anyone else ever seen this before?
