Ok, so I adjusted my valves at 105,000 miles. Following the school of thought that slappy valves are happy valves, I set them all at the loose ends of the clearance guidelines. Upon starting it up afterwards, the engine was very loud. The best two ways I can describe it is either as an exhaust leak near the engine or a diesel garden tractor....just a constant "rat-tat-tat-tat-tat" at idle. Runs ok, but seems to rev a lot in first gear without any corresponding increase in power. Also, it doesn't want to coast down hill; the engine holds me back so much that I have to stay on the gas through first gear and can't coast until it shifts into 2nd...and it is very loud hrough all of this It almost feels like I have too much compression, but I'm not sure if that makes sense....if I left my valves too loose, it seems that they make not open properly and could lead to too much compression, but again, I don't know if I'm on track with that theory or not.
My hope is that this is normal when adjusting valves to the loose side of things, but I just want to make sure I'm not doing more harm than good. Any help from those of you with much more mechanical knowledge than me would be greatly appreciated. Thanks!
