OK,
My first post here, and I put it in the wrong forum
Sounds good to me....a roof rack in the Racks, Hitches & Towing section ! :wink:Clarkm said:OK,
My first post here, and I put it in the wrong forum![]()
M6 x 1.0 pitch. (The common-normal one)eversavage said:What are the thread count for the screws used. 6mm was mention but doesn't thread count matter too?
paulj said:I bought an extra set of plastic covers, and trimmed those to fit around my brackets. Since I don't have many power tools (just an electric drill), I used a sheet metal nibbler to cut the plastic.
One thing, when cutting the plastic covers, note the difference between the right and left front ones. They appear nearly identical - but aren't.
paulj
As best I can tell, the Kim's car was found 5 miles to the NE of the 23/2308 junction (measured off of Google Earth). It is unclear how far they had driven up FS23, if any. At some point, though they ended up wandering along BLM34-8-36, which follows the north side of the ridge (23 is on the south and top of the ridge), eventually meandering above the Rogue River. They ended up 8 straight miles from the 23/blm junction, though a lot longer by road.Clarkm said:For 5 hours I parked my Element with wooden rack at the intersection of 2308 and NF-23 and on Oct 2, 2007 in Oregon.
Two months later, Searchers found the frozen body of James Kim at that location, or within a mile..
You can use a drill to trim the plastic- one of those step drillbits works very nicely- almost as good as a side mill.paulj said:I bought an extra set of plastic covers, and trimmed those to fit around my brackets. Since I don't have many power tools (just an electric drill), I used a sheet metal nibbler to cut the plastic.
paulj
Great ideal. What are you using to attach the yakima bars to your aluminum angle? Also, it looks like you have a lot of racking built onto the bars, for my own curiosity can you provide a pic of your whole rack system? Thanks.paulj said:Just to clarify, you drilled the holes for the 6 mm bolts in the angle steel, matching the threaded holes in the Element's brackets, right?
Here's an early version of my roof rack bracket, made from 1 1/2 aluminum angle
and a more finished version:
