Well, I sure hope I didn't wreck my transmission. I've ready through a lot of posts here tonight hoping to find a problem similar to mine but I didn't. Here goes. Today I had to tow a Honda Shadow motorcycle (about 500 lbs) about 200 miles on my utility trailer (about 350 pounds). Everything was going fine for the first half of the trip, then I got to slightly hilly terrain. As soon as the hills started, the Engine Malfunction light came on. I know this light usually comes on from leaving the gas cap off or from night tightening it enough so I pulled over and checked, and it was fine. As soon as I started to speed up to rejoin traffic, I noticed that the car was acting sluggish. Like it wasn't shift up the way it should. Then as I was speeding up and reached 70 miles on hour, it felt like my tranny disengaged and the car was in neutral it had no response to the accelerator until the speed got back down to 60. As 60 she was running okay though sluggish, but as soon as I hit 70, the tranny would disengage. I ended up pulling over again. this time I disconnected the negative batter cable for a couple of minutes. When I reconnected it and started the car, the Engine Malfunction light was off. As I sped off, there was no acceleration problem, I was able to cruise past 70 with no problems. I thought everything was fine. Then the light came back on and the symptoms started again. Even worse, leaving a red light I must have accelerated to fast, and the car started bucking. As long as I accelerated slowly, there was no bucking. Going past 70, the tranny disengages and doesn't respond til I'm back to exactly 60. It felt almost like it's some kind of safety feature that wouldn't let me drive past 70. I also realized that the car bucked when I tried to use the cruise control as I was trying to set it to 65.
I pulled the negative cable a couple of more times and sure enough, doing that obviously reset the light as well as something in the car because it ran and worked fine when the light was off, but as soon as it came back on the problems begin again.
I dont' know if towing the motorcycle was actually the cause because I don't think the bike and trailer weigh that much. but I have no idea what to do tomorrow.
Does this sound familiar to anyone?
